transfer case removal
Old Jan 15, 2012 | 06:55 AM
nextlevel's Avatar
nextlevel
Default transfer case removal
I have a 1995 dodge dakota 4x4. I cannot seem to get the transfer case out. The torsion bar crossmember will not let me slide it back enough to clear the transmission. Is there a trick to this?
nextlevel
Old Jan 15, 2012 | 12:45 PM
crazyjerry's Avatar
crazyjerry
is yours manual tranny ? if so i can tell you exactly how but if its auto trans then im not sure. service manual should offer some ideas
Old Jan 15, 2012 | 08:31 PM
nextlevel's Avatar
nextlevel
I finally had to remove the torsion bar adjusting bolt on the driver's side. Then I had to raise the transmission about 1" and pulled the transfer case back and rotated it clockwise and finished pulling it out.
nextlevel
Old Jan 15, 2012 | 10:24 PM
crazyjerry's Avatar
crazyjerry
ok you must have auto trans. manual trans is quit a bit simpler. slide tcase back couple inches so the input/output shafts disconnect then the whole thing drops out in the gap between tranny and torsion crossmember. never had to mess with torsion bars or jack the trans
