new distributor but truck still wont fire
Old Jun 17, 2012 | 08:28 PM
stuckoutwest's Avatar
stuckoutwest
Question new distributor but truck still wont fire
i have replaced the distributor and truck really wants to start 100% more than before but is still not firing seems to be missfiring tried everything we could think of with the firing order.... wants to go in all combinations but doesn't
we havew hayne's manual and know correct order.
do i have to set #1 spark plug to top dead center even if the new distributor set exzactly where the old one was?
i marked a line on the rotor and new distrib went in like a glove... have i failed to mark and align something else?
please help any info is much appreciated as i am stuckoutwest
thank you
Old Jun 18, 2012 | 01:09 AM
Crazy4x4RT's Avatar
Crazy4x4RT
2 quick possibilities I see.
1. Is you lined up TDC on #1 cly on the wrong stroke. Which the distributor shaft will need to be turned 180 degrees.
2. You have the distributor incorrectly positioned. This picture will help. You MUST have #1 cly TDC on compression stroke. The rotor pointing to the #1 mark on the pickup coil/cam sensor. It must be exact!
Old Jun 18, 2012 | 01:47 PM
stuckoutwest
my haynes manual has the cylinders labled backwards from the picture u just sent me not sure why....
going to investigate....
thank you
Old Jun 19, 2012 | 12:28 AM
1stG92's Avatar
1stG92
Default Same problem
Having the same issue here.Crazy sent this diagram to me and I followed it exactly as pictured.Brought #1 cylinder to TDC on compression stroke,lined the button to the cam sensor and reset the cam gear so all lined perfect.Still runs like ***.I know it's timing due to the popping and skipping.Fires right up now though but runs REALLY bad.
Old Jun 19, 2012 | 01:14 AM
AZ 360 Dakota's Avatar
AZ 360 Dakota
How many miles on your truck? Maybe the timing chain skipped that's why it feels like a timing issue. I just did a timing chain on my 5.9 with approximately 150K and that chain had 3/4" of slop compared to the 1/8" of play on the new one.
A.J.
Old Jun 19, 2012 | 12:27 PM
1stG92's Avatar
1stG92
157000 but had checked chain n gears and were fine.Set timing and both marks on cam and crank lined up.
