Fuel gauge
Old Jul 10, 2012 | 01:04 PM
Southern_Comfort's Avatar
Southern_Comfort
Default Fuel gauge
Hi,I have a 95 Dakota 3.9 auto ext cab 2WD.I Replaced the sending unit and pump assm, but the fuel gauge only reads between a 1/4 and 1/2.If I remove the pump and move raise and lower the float arm manually,the gauge responds.The Gauge worked fine prior to fuel pump R&R I see 2 marks on the top of the fuel tank that look like indexing marks,and mark on the pump that i lined up with those marks,I have left the locking nut for the pump assembly slightly loose so i could rotate the pump a little in case the float was hitting the side of the tank but still no luck.Any ideas?
Old Jul 10, 2012 | 09:31 PM
siggie30's Avatar
siggie30
Sounds like it is still hitting the side. I had a similar issue after reinstalling my tank, but I reseated the float and no problems afterward, Try re-reseating it.
Old Jul 11, 2012 | 10:47 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Yes sounds like it just needs to be adjusted. This post has some details on adjusting it.
https://dodgeforum.com/forum/1st-gen...mp-died-2.html
Old Jul 11, 2012 | 11:38 PM
Southern_Comfort
got it,Thanks Guys.It was still hitting the side.Seems like i turned it a long way but it seams to be working now.I will runn a tank of gas through it b4 I put the bed back on Just to be sure
