220,xxx miles on original motor and tranny?
Old Jul 21, 2012 | 02:02 PM
v6dakota95's Avatar
v6dakota95
Thumbs up 220,xxx miles on original motor and tranny?
alright so my trucks got 220,xxx on the original drivetrain, it doesnt burn or leak oil.. the transmission has its moments but its okay... thing is should i go ahead and get the motor or tranny rebuilt before i hit 300,000 or just leave it alone?
Old Jul 21, 2012 | 05:36 PM
Crazy4x4RT's Avatar
Crazy4x4RT
If it is okay then your best bet is to do good maintenance on it. Also doing compression and leak down test on the motor.
Old Jul 21, 2012 | 08:06 PM
SEPA92Dakota's Avatar
SEPA92Dakota
Literally if it ain't broke, don't fix it. If you're paranoid or anything then start stockpiling the parts for the rebuild piece by piece/week by week assuming you'd want to do it yourself.
Old Jul 21, 2012 | 09:14 PM
shadowthedakota's Avatar
shadowthedakota
knock on wood...right now...
Old Jul 21, 2012 | 09:31 PM
knoxy_14's Avatar
knoxy_14
im just about to hit 300k on mine on original everything main thing it wont go into overdrive i need to replace the little sensor thing
Old Jul 21, 2012 | 10:10 PM
Riden LOw's Avatar
Riden LOw
I bought two trucks that were being sold for parts and built one well I'm still building on it, anyways the motor I took from the running truck with 221000 miles ended up having lots of blow by. I disassembled it to find that six of the eight pistons had the compression ring gaps lined up. I went ahead and took the block, heads, and crank to a machine shop. The cylinders still had the original honing marks visible not like new of course but still visible. I had a valve job done, crank just needed polished, and a quick honing was done. Point is if this motor would have been built correctly from factory it would have been a engine capable of quite a few more miles so I wouldn't fret it.
Old Jul 22, 2012 | 12:27 AM
volaredon's Avatar
volaredon
yup I just changed the original from 1995 alternator on a Ram 1500 4WD with 291K a few weeks ago that has had 3 or 4 fuel pumps and as many sets of front axle U joints but motor trans and front/rear ends are original and untouched other than maintenance.
