i need info
Old Jul 25, 2012 | 12:52 AM
Dbdscores's Avatar
Dbdscores
Default i need info
OK I have a 93 Dakota with the 3.9l v6 I wanna add horse power but I have a relatively low budget like 1000 bucks a month any ideas?
Old Jul 25, 2012 | 05:51 AM
JR318's Avatar
JR318
Are you saying you have $1000 a month to spend or $1000 a month to live and play? The best bang for your buck will be to save up and do the v8 swap. You will spend more on a v6 trying to get v8 power then just dropping in a 5.2 or 5.9
Old Jul 26, 2012 | 04:52 PM
nemesis158's Avatar
nemesis158
that is if you can find a 5.2 or 5.9
but yes you can get more out of the V8s, especially since you can actually get a mopar performance PCM for it. For some reason they only made 200 performance PCMs for the V6s
Old Jul 26, 2012 | 06:08 PM
JR318's Avatar
JR318
There's 5.2 and 5.9 all over just have to look in other vehicles to. They came in the van also. Craigslist and ebay too. Ive found them here for around $500on Craigslist.
Old Jul 27, 2012 | 03:14 AM
keilkravec's Avatar
keilkravec
I might actually ask you to locate an engine if my local yard doesnt have a junked one...seeing as i could pick it up since im only a state away and a running engine is preferred to a junked one. Availability is pretty scarce in some areas..and plentiful in others. You and Crazy have good yards with plentiful parts that havnt yet been bone picked like buzzards on fresh kill. Around my area there is slim to no good mopar used stuff :/
But as to your budget Dbd, is it total for live and play? or is that just play? If you want to swap in a V8 your ballpark will most likely be around $900-$2500 depending on what you can find in junk yards and get good deals on, want to do with the engine regarding performance, getting your transmission rebuilt to handle the power, or if you need to rebuild the motor theres always that can of worms as well.
I'd say look over the FAQ's to get some ideas or find one you like so you can make a plan for what you want to do with your truck. Once you got that then you got a good bunch of info in the forums to help you along the way and good guys to answer questions that arnt listed.
Old Jul 27, 2012 | 05:48 AM
JR318's Avatar
JR318
What are your expectations for hp and torque? What will the truck be used for(towing, daily driver, street/strip)? Are you worried about gas mileage? There are several factors to think about and then plan a build that will work best for you and your needs. Once you decide on wich way you want to go post your decision and we all will help with questions and advice. But at the end of the day do what you want to do and you will be that much happier with your truck.
Old Jul 27, 2012 | 02:21 PM
nemesis158's Avatar
nemesis158
i would also like to point out that if your truck is a manual tranny, you will need to find the v8 with a tranny w/transfer case from a 94-96 (93 v8's didnt come with a manual)
in this case you will also have to find exhaust manifolds for a 93 v8 (94-96 have smaller exhaust exits)
Old Jul 27, 2012 | 06:56 PM
JR318's Avatar
JR318
You can get headers from summit for $200.
Old Jul 28, 2012 | 11:25 AM
keilkravec's Avatar
keilkravec
Thanks for the link there, now I don't have to use sock manifolds.
Old Jul 28, 2012 | 12:23 PM
Dbdscores's Avatar
Dbdscores
The 1000 is a mixture of both I have only a couole bills so after them I have 500 to 800 to play withand I really don't want to do the swap I just want a little more get up and go
