Alternator Died.
Old Jul 27, 2012 | 11:59 PM
Gasguzziler's Avatar
Gasguzziler
Default Alternator Died.
So I got a check engine light today and when checking the codes seen that the code was for my alternator not charging. I tested it today when I got home and for sure it is not working. Well I do not have $100+ right now to drop on a new alternator so I was wondering if there were any alternators that are from other dakotas or mopars that will work on our motors just in case I can not find one off of a 5.2 when I go to pic n pull this weekend. Like the ones off of smaller motors or such. Any help would be greatly appreciated. My truck is a 1994 dakota with the 5.2 magnum motor
Old Jul 28, 2012 | 07:18 PM
Gasguzziler
Well I guess to answer my own question and just in case someone in the future ever needs to know, what I seen today when I went to the pick and pull is that the v6 and v8 alternators are interchangeable. You just have to look out for the actual amperage of the alternator. I knew that there was a wrecked 95 dakota at the pick n pull with the v8 and when I got there the alternator was actually 90 amp but the 96 with a v6 had the same part number 120 amp that I had pulled off of my 94 dakota with the 5.2l.
Old Jul 28, 2012 | 07:58 PM
Crazy4x4RT's Avatar
Crazy4x4RT
You can always go to www.napaonline.com or www.rockauto.com they list the interchange for parts. For the alternator it would probably be V6 and V8 Magnums 92-03. Rams, Dakotas, Ram Vans, Jeep GC.
