cruise control swap
Old Jul 29, 2012 | 01:44 AM
DMG411's Avatar
DMG411
Default cruise control swap
First off Hi all new to the forums! i just picked up a 93 Dakota sport reg cab 3.9 v6 4x2 a few days ago. its bone stock so I've been hitting the junk yard grabin parts left and right to up date it a little.
I have the stock Dakota w/o cruise control. my local junk yard has a fully loaded 94 gen 1 ( not sure if its v6 or v8) kota with CC in it.
1.could I pull all the parts including the steering column and drop them in my kota?
2.would my original computer work? (if the junk yard kota is a v6)
3.did they use a universal wire harness in the early gen 1's?
4.has anyone on the forum here done it?
hope you guys can help ~ Big D
Old Jul 29, 2012 | 09:48 AM
shadowthedakota's Avatar
shadowthedakota
everything should be plug and play...but i'm not completely sure on this. i know my 91 didn't come with cruise but it has all the connectors.
it should work with your current computer
Old Jul 29, 2012 | 01:34 PM
DMG411's Avatar
DMG411
Thanks Shadow that is kinda what i thought just wanted a little reassurance I have the right idea, i'll give it a shot and report back afterwords
Old Jul 30, 2012 | 12:35 AM
shadowthedakota
let me know. im sure someone else plans on doing this and when i swap to an 04 dakota/durango steering column i plan to install cruise control...its sooooo handy...
Old Jul 30, 2012 | 09:35 AM
keilkravec's Avatar
keilkravec
This just reminded me that I was needin to ask about mine, I'm thinking there is a vaccum leak somewhere since mine will not engage...hasn't for a good bunch of years now. Anyone got ideas on where it might be or if it's a common problem spot?
Old Jul 30, 2012 | 05:22 PM
shadowthedakota
its been so long since i got rid of my 93 which had it. first i would check the fuse. someone had put a 5amp in mine and it blew the first time i tried it. i put a 10 amp in and it was fine ever since. otherwise check the connector at the module, then follow the vacuum lines off the module going into the other lines
