v6 cranks a lot before start
Old Aug 2, 2012 | 12:44 PM
bran1har's Avatar
bran1har
Default v6 cranks a lot before start
My dad just got a used 96 dakota v6 manual trans. When the engine is cold, he noticed that when he turns the key the engine cranks over a few times before it starts but then everything is fine. But if the engine is hot it just starts right up. He is worried that in the winter when its really cold it isn't going to start. So far we have replaced the wires and plugs but no difference and also the battery. It turns over like 3 times before starting, he thinks it should start right up. Is this normal?
Also when the engine is idling it makes this very soft rattling sound that is concerning him. It sounds like the timing chain. Does this mean it should be replaced? What should be done to correct this problem. The engine has 116,000 miles.
Old Aug 2, 2012 | 03:11 PM
v6dakota95's Avatar
v6dakota95
mine use to do that, i changed the fuel pump and it started right up after that and still does. just take off the bed and change it dont drop the tank its a pain to do it that way.
Old Aug 3, 2012 | 01:29 AM
Crazy4x4RT's Avatar
Crazy4x4RT
There is a check valve inside the fuel pump to hold the fuel pressure when the pump isn't running for fast starts. That can fail and cause poor start up when left sitting for periods at a time. It is not replaceable. You would have replace the entire fuel pump sending unit or install an universal check valve. The FAQ's in this section has a great write up. I would test the fuel pressure to see if that is what it is doing dropping overnight.
Old Aug 3, 2012 | 12:40 PM
bran1har's Avatar
bran1har
Thanks for all the info. Im going to order a new fuel assembly soon and put it in. I need one anyway because the fuel level float is broke. I'll start a new thread on the timing chain, that im also not sure about.
