1989 / 1992 fitment questions
Old Aug 2, 2012 | 04:38 PM
Jacob1189's Avatar
Jacob1189
Default 1989 / 1992 fitment questions
I have a few questions I hope someone can answer...
1) would the front seats from a 92 extended cab fit in a regular cab 89?
2) would any of the suspension fit from the 92>89
what would generally cause sagging on the front end? my driver/front is sagging enough that my 31's grind if i turn just right or am turning during a pump, and i dont have that issue with the right side.
Old Aug 3, 2012 | 01:33 AM
Crazy4x4RT's Avatar
Crazy4x4RT
1. My guess is yes it would bolt right in, unless the 89 has a full bench seat which it may not have the center bolts.
2. It depends on what you want to swap, sounds like you just want the springs which should be the same.
3. Sagging is caused by time and use. It sounds like your not really getting sagging, that it needs an alignment more.
Old Aug 3, 2012 | 02:16 PM
Jacob1189's Avatar
Jacob1189
I actually had an alignment just recently (after adjusting the torsion bars)
So the springs will likely fit, will the changing of them require another alignment?
