1996 dodge dakota 5.2
Old Jul 12, 2012 | 12:39 AM
dodgeguy318's Avatar
dodgeguy318
Default 1996 dodge dakota 5.2
my trans died and i was wondering what years that were interchangeable for the auto.
Old Jul 12, 2012 | 02:06 AM
Crazy4x4RT's Avatar
Crazy4x4RT
1996-03 97-up most 5.2 autos came with the 44re so make sure you get the correct transmission 46re which will be on a few 5.2's and all 5.9's
Old Jul 12, 2012 | 11:07 PM
dodgeguy318
Question
the 46re out of a 5.9 will work is it going to be plug and play tho id figure that electrically it would be different
Old Jul 13, 2012 | 10:40 PM
grswat's Avatar
grswat
If yours is a 2wd I have a good 46re sitting in my garage. Has 120k total on it but was rebuilt about 60k.
Old Jul 15, 2012 | 12:55 PM
dodgeguy318
its a 4x4
Old Jul 18, 2012 | 06:01 AM
JR318's Avatar
JR318
I think there was a 46re in the for sale section but not sure if it is what you need. Ive also heard that you can just swap the tail shaft section between the 2wd and 4wd and use your tcase.
Old Jul 19, 2012 | 07:38 AM
grswat's Avatar
grswat
According to my transmission guy changing a 2wd to 4wd or vice versa is basically a full rebuild.
Old Jul 19, 2012 | 06:09 PM
shadowthedakota's Avatar
shadowthedakota
its not a full rebuild if you can save the gasket.
heres the link i found on it
http://mallcrawlin.com/forum/showthr...way!!!-writeup
good thing i saved this puppy...
Old Jul 19, 2012 | 10:50 PM
Crazy4x4RT's Avatar
Crazy4x4RT
IIRC you got to remove the OD unit and swap it onto the other transmission. The big problem is you got to have a 4wd transmission to get the 4wd OD unit from.
In my mind if your taring it apart just to do that you might as well just throw the 4wd transmission in and don't have to open it all up.
Old Jul 20, 2012 | 12:29 AM
wyrmrider's Avatar
wyrmrider
Bottom line is that if you have a good 96 or later (not the early one with the three wire connector) 46re 2 or 4wd front end you could rebuild your 4x4 OD and swap
What went out?
If it was the OD you can rebuild to diesel (47) specs
If it was the front end you can get a 47 core and swap the guts
I've got the straight cut diesel gears in mine
no more thrust on the thrust washers which are the biggest source of failure
I think i have 9 clutches in the OD- the diesel just added one more (than V8 many more than V6) increasing the pressure slightly
If your unit is burnt up then let's talk oiling mods
If your big OD spring is sagged get Transgo's heat treated one
So what let loose?
