89 transmission problem
Old Aug 9, 2012 | 07:35 AM
kilroyshadow's Avatar
kilroyshadow
Default 89 transmission problem
I have a 1989 dakota with the 3.9 in it and i think the 904 transmission and it won't kickdown to speed up and wont shift into overdrive. there is a dual solenoid for both but idk if it will fix it or not. any advice?
Old Aug 9, 2012 | 11:54 AM
Crazy4x4RT's Avatar
Crazy4x4RT
It could be the TV cable or I think the early years had a rod setup. That could be the downshift problem. I'm not to sure if OD was electronically controlled on the early years if so maybe a bad speed sensor to wiring issues.
I would suggest taking it to a transmission shop, most will do free test drives. Get their opinion and go from there.
Old Aug 9, 2012 | 09:04 PM
kilroyshadow
well when i have the od button on and get up to 50 it makes a feint whining sound but when it gets up to 55 it stops and the solenoid i was talking about is a kickdown and overdrive solenoid thats why i thought that was the problem
Old Aug 10, 2012 | 09:54 AM
Crazy4x4RT's Avatar
Crazy4x4RT
So are you pressing the OD button every time? The OD button turns OFF the OD when you press it and the light is on. It is for when your towing and you need to turn OD off.
OD is on automatically and controlled by the PCM. DON'T touch the OD button.
Old Aug 10, 2012 | 10:18 PM
kilroyshadow
i guess my od buttons hooked up backwards than it used to work but only when the button was on then it quit working
