Replaced IAC FOUR (4) times - it was my PCM :( - here is how I found out
Old Dec 28, 2012 | 09:07 PM
  #31
moparnut38's Avatar
moparnut38
now that sounds like a great idea....I am in on getting together and shoot the breeze and have a few cold ones.
I havent seen my truck now in a month as it sits in storage out on French Road and I miss driving it.
If all my plans go well I will have a long box Dakota with an extended cab 2wd sometime in the next couple of years.
Old Dec 29, 2012 | 10:54 AM
  #32
Purple Neon Guy's Avatar
Purple Neon Guy
Sounds great! I had mine out last night, been a bit sick and needed some meds so I went for a drive, even with junk tires it was still a blast on 3 inches of fresh powder!
Old Jul 24, 2014 | 08:11 PM
  #33
bcord8335's Avatar
bcord8335
Default having issue
have this 94 dakota changed about everything after the computer went out thinking it was something else on my sec computer an it misses real bad for about 2 min after driving it like 6-10 min once it stops it seems fine but think its getting worse im getting only code 62 PCM failure SRI mile not stored what does this mean? an what do i do to fix this? or whats this miss popping noise im hearing? an what do i do about it? please need help b4 spending more $ changed 02 sensor,temp sensor,tps,wires,plugs,distributor cap an rotor, took cat converter out belt tens an belt, idle sensor not sure what else there is? please help thanks
Attached Thumbnails Replaced IAC FOUR (4) times - it was my PCM :( - here is how I found out-dakota-new4.jpg
Old Jul 25, 2014 | 09:49 PM
  #34
Tom A's Avatar
Tom A
Section Moderator
First of all, thank you for using the forum search feature. But, since this thread is a couple of years old, you would probably get more replies and hopefully better information if you start a new thread.
Good luck!
