What size are rubber hoses on transmission?
Subscribe
Sep 7, 2012 | 08:34 PM
I wonder if anyone knows what the id is on the soft rubber hose portion of the transmission line that goes from the trans to the cooler?
I am wondering becuase I want to install a Magnefine filter on it.
Thanks,
Ryan
Reply 0
Sep 8, 2012 | 01:00 PM
Replace all lines with 1/2 inch oil proof hose for much more flow (there' is a reason Diesels use 1/2 inch
you will cut your backpressure about 15 lbs for each line and another 15 lbs if you use a 1/2 inch in and out cooler and bypass the radiator
If you are in a cold weather state let me know
Reply 0
Sep 9, 2012 | 12:48 PM
I hadn't planned on changing them completely, I was going to splice in a filter and needed to know what the inner diameter of the hose is so I could put barbs into it, in order to mount the filter. The sizes I am wondering are 3/8, 5/16, and 1/2". I'm ruling out half inch due to above post so y'all think its 3/8 or 5/16? Thanks
That is interesting about the bigger lines reducing pressure and I do live in a cold climate state.
Reply 0
Sep 11, 2012 | 01:48 PM
most likely 3/8
cold climate state use a thermostat or route through radiator and cooler.
WE put gauges before and after cooler and at input and output of trans.
The 3/8 lines are much better than the old 5/16 but not near as efficient as 1/2
What tranny do you have?
late tranny has a filter
I use the filter before the coolers to protect the expensive coolers from converter failure not just to protect the trans after the cooler
Reply 0
Sep 11, 2012 | 06:11 PM
wymrider is correct, it is 3/8"
Reply 0
Subscribe
