Sounds like you may have to remove all the panels to access the ignition switch and may need to replace the lock. Also a quick note most manual transmissions have a push button to release the key.
Well. Saw that cable to shifter snapped. Pulled down to get it to say park and still didn't release. $10 for new key thing plus shifter doesn't lock securely.
Got key out. Have to lift slightly on shifter. Any ideas where to get a bracket for shock absorber in back that attaches to frame? And right side drum back plate thing?
