ive replaced all parts an my 1994 dakota stiil no pedal
Old Sep 18, 2012 | 08:59 PM
jackie1973's Avatar
jackie1973
Question ive replaced all parts an my 1994 dakota stiil no pedal
I have replaced mastercylinder, power booster, rear antilock brake valve bleed repeatedly stiil no pedal will feel like its there when truck is off after bleeding feels good turn on truck pedal goes away im at a loss . Bought truck very used i found out former owner hauled a way over sized trailor behind it dont know if it means anything our not but thought id put it out there any ideas ?
Old Sep 19, 2012 | 11:14 PM
djibara's Avatar
djibara
Sounds like you still have air in the lines or calipers start at the farthest point from the master cyl and work your way closer keeping the master full of course if that dosent do it I would try a power bleeder
Old Sep 20, 2012 | 12:41 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Did you bleed ALL 4 brakes?
I will move this to the 1st generation Dakota sub-forum.
Old Sep 23, 2012 | 10:02 PM
RYCOMA79's Avatar
RYCOMA79
that's because with the truck off you are not using the power booster when you start the truck it builds vacuum in the booster which makes breaking much easier. Is the pedal traveling all the way to the floor if so yes you have air in the lines or a leak. if it takes a lot of force to stop the truck then the booster maybe buggered
Old Sep 23, 2012 | 10:07 PM
volaredon's Avatar
volaredon
where abouts are you located?
