92 dakota need help with problem
truck has been setting sence 09 just got it to fix up got it running and ran it for two days changed water pump it was leaking ran to parts house killed it in drive way two hours later went to start it turns over fine has nespark and cant here fule pump power up checked power to coil has none checked poer to crankshaft post. sensor no power all fuses are good cant see a check ing. light when i turn the key on at all could the computor have gone out? dont know what else to check please help if you know anything about this problem
