Cowl Drain = Fender Rust Spot?
Old Oct 11, 2012 | 08:42 PM
pinkfloydeffect's Avatar
pinkfloydeffect
Unhappy Cowl Drain = Fender Rust Spot?
Why is it all 87-96 Dakota's have a spot rusted right here on the fenders? Something must cause it, does the cowl vent drain into the fenders or something? When I finally find a clean pair of fenders I'm going to POR-15 the backsides but there must be something else I can do like direct the water flow?
Old Oct 11, 2012 | 08:49 PM
nemesis158's Avatar
nemesis158
probably more likely due to rocks and the lack of a mudflap. i only have mudflaps on one side of my truck, and i can tell you rocks like to chip the paint without them.
Old Oct 11, 2012 | 08:53 PM
pinkfloydeffect
When I put a hammer through the rust spot it was full of wet dirt and leaves which makes me wonder how it got in there to begin with...
Old Oct 11, 2012 | 10:02 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Yes the cowl does drain in that direction. So all the rain, dirt, mud, leaves goes down and gets stuck. It is a very common problem on all vehicles.
Old Oct 11, 2012 | 10:15 PM
pinkfloydeffect
What the hell that was done intentionally by the car manufactures, does it drain into both sides?? What if I just cut an opening in the bottom of the fenders on the backside then everything would just fall/drain onto the ground?
Old Oct 11, 2012 | 11:39 PM
shadowthedakota's Avatar
shadowthedakota
there is a spot for the water to drain there but when leaves and crap clog it up then the water sits and corrodes. i have yet to have that problem on any vehicle but then again i always clean the cowels off or my friend does it for me.
Old Oct 11, 2012 | 11:44 PM
pinkfloydeffect
I'm thinking about putting residential window screen under my cowl to help prevent this.
Old Oct 12, 2012 | 01:11 AM
marcar1993's Avatar
marcar1993
Stuff will still get in there... Every once in a while you need to remove the inner fender or the lower fender bolts and blow all the crap out with a hose. That is an issue on almost ALL cars, and that really is the only solution, unless you have a garage kept show car that never sees water and doesn't get crap falling on it.
