ways to make my dakota a little faster??
Old Oct 25, 2012 | 03:22 PM
Moparornocar39's Avatar
Moparornocar39
Default ways to make my dakota a little faster??
I have a 1990 Dodge Dakota with a 3.9l v6 and i really wanna give it some more get up and go. I was thinking put in 8 mm spark plug wires platnium spark plugs k and n air filter but idk what else i could do? also should i put a cold air intake even though my truck already has a factory setup air intake? any input would be appreciated. thanks!
Old Oct 25, 2012 | 03:52 PM
ricekiller's Avatar
ricekiller
best way to make your dakota faster = swap a v8 into it.
Old Oct 25, 2012 | 04:42 PM
inuchan187's Avatar
inuchan187
don't get spark plugs and wires until you actually need new ones. the performance increase isn't noticable. get a k&n filter that drops into your stock intake and remove the piece of plastic on the grille that covers the intake pipe. Buy a glasspack and replace your muffler keeping the rest of the stock exhaust. after that, you may as well get a v8. a 318 magnum in good condition can be found for $300. you would be spending that much on plugs, wires, filter, and exhaust kit, so why not add 2 cylinders instead. For well under $1000 including the engine, you could have 350 hp vs spending $1000 on the v6 being lucky to reach 250 hp
Old Oct 26, 2012 | 10:34 AM
ricekiller's Avatar
ricekiller
yea, its almost too easy to swap a v6 for a v8 lol. even easier if you have the whole underhood part of the v8 harness.
Old Oct 26, 2012 | 02:10 PM
Moparornocar39
how hard is it to drop in a 318? and wouldn't i need to get a new tranny too?
Old Oct 26, 2012 | 02:50 PM
ricekiller's Avatar
ricekiller
to my knowledge, the magnum 3.9 is very similar to the mgnum 5.2. just 2 cylinders short. pretty sure the bell bolt pattern is the same as well. do you have a stick or auto trans? my stick bolted right up. all you have to do if your going to reuse the v6 harness is run the extra injector wires for the 2 extra cyllinders and get a v8 pcm. motor mounts are the same.
Old Oct 26, 2012 | 08:08 PM
eddys89vert's Avatar
eddys89vert
if its a 90 model it has the old 125hp LA engine block..........might as well yank it and switch to the Magnum engine..but that involves a crap load of work haha........oh and the tranny should last a little while...........no need to change right away
Old Oct 27, 2012 | 02:25 AM
inuchan187's Avatar
inuchan187
all you would need is the engine wiring harness, which if your lucky is still on the motor, the pcm, radiator, and maybe the engine mounts. I wouldn't really consider that a crapload of work.
Old Oct 27, 2012 | 09:31 AM
JR318's Avatar
JR318
Here is a pretty good article on a 400hp build. http://www.popularhotrodding.com/tec...e/viewall.html
Old Oct 27, 2012 | 01:02 PM
Moparornocar39
so its pretty much cheaper and less hassle to get a newer truck?lol
because i've never switched engines out before and itd seem like i could esily screw something up lol
