12 second dakota =)
Old Oct 27, 2012 | 12:11 AM
keilkravec's Avatar
keilkravec
body panels will have to be custom, i dont know of anyone that makes them.
The 9.25 rear is about an inch wider than the 8.25, and the shock mounts will need to be ground off and re-welder on to the correct spots, and you will need much more than just a cam and heads, but the 360 block is the way to go.
Old Oct 27, 2012 | 02:36 AM
inuchan187's Avatar
inuchan187
fiberglass hood is about the only body panel you will find readily available. If you know somebody who owns a machine shop your best bet may be a bored and stroked motor depending on how cheap he is willing to do the machining for you.
as far as heads and cam, stock heads have a max of .500 lift and edelbrocks have a max of .580 without modification. with lift that low, you might need a solid roller cam to get the power you need to run 12s. Not sure if anybody else makes better heads for these.
Old Oct 27, 2012 | 08:05 AM
dakotakid17's Avatar
dakotakid17
Default 12 sec dak
alright cool cause i can get a fully Assembled set of aluminum fully together for i think like 800 bucks or so. but as for the panels do you think my best bet is to just take my bumper and fenders to a auto body shop to have them used as molds assuming if they will take that kind of work. another thing i was thinking of was my drive shaft. i know a place in ri that makes awesome aluminum drive shafts for a good price you guys think that would be worth the effort?
Old Oct 27, 2012 | 09:24 AM
JR318's Avatar
JR318
This article may give you some ideas. Im not sure how well the engine quest are but ive been thinking about buying a set as soon as the budget allows. http://www.popularhotrodding.com/tec...e/viewall.html
