tranny question
Old Dec 1, 2012 | 09:24 PM
4x4troy's Avatar
4x4troy
Default tranny question
I just got a 1993 Dakota with a 5.2 ,auto and 4x4. from the looks of it and info I found on here it appears to be a 46rh. the tranny has no reverse and slips bad in forword gears. my question is. can a 93-98 jeep grand Cherokee 5.2 46rh work in my truck? like just a simple swap no making things work. I ask because I cannot find a 46rh anywhere in my area for my Dakota but I have found lots for the jeep. what about one from a dodge ram and if so what years do I need to look at. and will my transfer case bolt to one of these trannys?
Old Dec 1, 2012 | 09:48 PM
Crazy4x4RT's Avatar
Crazy4x4RT
No the Jeep GC ones won't work.
Your choices is Dodge Ram, Dakota, Ram Van. 92-95 V8 Magnum a few Ram V6's came with it.
Old Dec 1, 2012 | 11:50 PM
4x4troy's Avatar
4x4troy
what just a 92-93 ram or Dakota?will my Dakotas tcase bolt on to the rams tranny...as long as its a 4x4 tranny or will I run into output shaft spline and length differences?
Old Dec 1, 2012 | 11:53 PM
4x4troy's Avatar
4x4troy
also will one work from a 360 powered 93 w250?
