Weak Heat
Weak Heat
My 94' will blow a SLIGHT amount of heat after its been running for 20+ minutes, its just barley enough to defrost the windshield, but me or any other passengers are still shaking from the cold. Any idea what it could be? I have everything on full blast but I get just a tiny bit of heat..
make sure coolant overflow tank is at the mark on the tank and also make sure the radiator is fileld to the cap. If there is a small cap on the hose going to the cab, take it off and make sure the hose is full of coolant. If the radiator was full and the hose is not, there could be other problems. If the temp gauge inside the cab is not close to half way , change the thermostat. Make sure you put in either a 180 or 195 degree thermostat. Anything lower, and you will not get much heat. Make sure your air conditioning is not on. Look at the pulley and make sure the center part is not moving. If a/c is off and the center is spinning, you either have an electrical problem or need a new compressor.
