where does the sensor that plugs in here come from?
Old Dec 5, 2012 | 10:43 PM
bghosted's Avatar
bghosted
Default where does the sensor that plugs in here come from?
just changed the engine and it has taken quite a while to get done so i forgot where this sensor comes from... thanks for any help!
Old Dec 5, 2012 | 10:46 PM
bghosted's Avatar
bghosted
http://tinypic.com/r/313rwop/6
sorry i forgot to include the link!
the sensor is down at the bottom like on top of the where the drive shaft is.
Old Dec 6, 2012 | 01:32 AM
Crazy4x4RT's Avatar
Crazy4x4RT
I'm assuming what you say by drive-shaft you mean front axle. If it is on top of the axle it is a Central Axle Disconnect for the axle. It has vacuum lines running to the transfer-case and then to the engine. The 4wd switch is there as well.
Old Dec 6, 2012 | 02:32 AM
bghosted's Avatar
bghosted
Default not sure if it is the c.a.d.
it seems to be a sensor... i remember disconnecting it but now that i have everything back together there is nothing left to connect to there. so if i was going to look for that sensor where would i start? and if it wasnt there were would i look next?
Old Dec 10, 2012 | 12:33 AM
moparnut38's Avatar
moparnut38
Do you have the coil plugged in as that is right on that side in that area
Old Dec 10, 2012 | 09:01 PM
shadowthedakota's Avatar
shadowthedakota
thats the plug for the 4wd light just below the t/c shifter. there should be a connector with 2 wires running out of it that is about 2ft long and plugs in some where by either the upper rad hose or near the back of the motor. i remember pulling that off of my truck when i tore it down. thought it was a little wierd to be run like that.
