Transmission
Old Dec 27, 2012 | 03:40 PM
ohiojack's Avatar
ohiojack
New Member
Default Transmission
Well, I had to bite the bullet. My transmission in my dakota is acting worse and worse. I just dropped it off at Earl Brothers transmission shop. My estimate was between 1200-1500.00 total rebuild with new torque convertor. My torque convertor was not disengaging when I was coming to a stop. I could downshift manually, but on upshifting it would lockup on shifting to second gear. I get a year warranty/12,000 mile. It didn't sound all that bad. The shop is suppose to call me tommorow with more details after they have it torn down.
Old Dec 27, 2012 | 08:26 PM
volaredon's Avatar
volaredon
after fighting w/the trans on my 94 Dakota I bougt a 93 clubcab with a bad trans and fixed it permanently... I pulled the automatic out, and put a manual trans (5 speed) in
Old Dec 28, 2012 | 12:12 AM
moe7404's Avatar
moe7404
Default trans
be sure you have your shop remove the check valve in the coolant line, AND flush the lines.
sorry its a cut and paste
man o man i about forgot yes its a cut & past sorry. __________________
after you clean the trans. add this to your*chrysler*trans. an external fluid filter
1. go to auto-zone. get 2210, its called a power steering filter, but it is for transs to. it is for 3/8 tubing. by (magna-fine) be sure to use high pressure hose. Reff:http://www.magnafilter.com.au/magna-fine.html*
2. for other sizes wix 58964 5/16 tube size reff:http://www.wixfilters.com/filterlook...sionfilter.asp
NEW SUBJECT: .distributor moisture fix. Some chrysler distributor cap that has an air vent, needs to have the vent plugged. Best to use JB-weld. But there might be some brands that run air through as part of the system, dont seal them
__________________
Old Dec 28, 2012 | 09:33 AM
ohiojack's Avatar
ohiojack
New Member
The shop said that they would remove the check valves on the lines. I'm thinking about dropping off a trans cooler that my son bought brand new for his old jeep, to the transmission shop.
