93 Dakota problem, please help.
Old Jan 3, 2013 | 08:50 PM
mellonhead2's Avatar
mellonhead2
Angry 93 Dakota problem, please help.
Fuel pump is pumping, checked wires, changed fuel fitler. Sometimes will start and run fine other times will start. After a few awhile go back and it will start and then same thing over and over. Any suggestions on what is going on???
Old Jan 4, 2013 | 01:42 AM
Crazy4x4RT's Avatar
Crazy4x4RT
So it won't start sometimes? You didn't say!
While it is not starting check to see if you got spark to ALL plugs and check your fuel pressure at that time, and check to see if the ALL fuel injectors are spraying correctly.
Old Jan 18, 2013 | 04:37 AM
daksnbeers's Avatar
daksnbeers
Yeah check to see if you get spark or not and fuel pressure when it's not starting.
Also check your flash codes that ussualy helps give a general idea of the issue.
If you don't have a fuel pressure gauge you can ussualy put a deposit down on one and barrow it from a auto part store.
Old Jan 18, 2013 | 04:40 AM
daksnbeers's Avatar
daksnbeers
Oh also just because you hear the fuel pump turning on as you turn the key doesn't mean it's pumping enough. Mines was on the verge of going bad since i bought my truck managed to get 6k miles out of it then truck just wouldn't start at all still hearing the pump kick on i replaced the pressure regulator which didn't help then i did the pump has been starting like a champ even in colder weather for the past 3 months have put about another 4k on it.
