Question for discussion
Old Jan 6, 2013 | 02:15 PM
marcar1993's Avatar
marcar1993
Default Question for discussion
What would be the largest diameter tire you guys would run with 3.55 gears?
From my math a 35 with 3.55's would be = to running 31's on a 3.14 gear.
Opinions?
Old Jan 6, 2013 | 08:34 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Largest on 3.55 I would say 33's. Most people don't change gears when going with taller tires. Nobody really has complained about to much lack of power with 33's on 3.55.
To me I say 31's is great for 3.55 for great highway and good torque. 33's are great with 3.90. And 35's 4.10, 4.56 may be to low of a ratio for good freeway.
Old Jan 6, 2013 | 10:19 PM
Tom A's Avatar
Tom A
Section Moderator
I ran 3.55s with 33s for a little bit before I switched to 4.10s. It might be ok if you live in the flatlands, but it kinda sucked with all the hills out here.
Old Nov 29, 2017 | 12:32 PM
Newfie36's Avatar
Newfie36
Default Rambox
The lights in my 2012 dodge ram longhorn is not working... Tried to find a fuse had no luck..... Any suggestions
Old Nov 29, 2017 | 02:18 PM
Try posting in the correct section, and not hijacking someone elses thread. You want fourth gen ram tech.
