Interchangeable years?
Old Jan 31, 2013 | 03:12 AM
T.C.'s Avatar
T.C.
Originally Posted by moparnut38
yes that should all be the same. The only differences between the 1987-1990 and the 1991-1996 is the front end sheet metal and the motors as the 1991-1996 are all multi port fuel injected and the 1987-1990 are throttle body fuel.
Sorry to correct you there Mopar-nut I believe that the 1991 are throttle body fuel injected, also that the 96 runs OBDII instead of the OBDI.
Old Jan 31, 2013 | 11:15 AM
DakotaRT1993's Avatar
DakotaRT1993
and I think 87's were carbs too
Old Feb 10, 2015 | 10:47 AM
tswan5105's Avatar
tswan5105
Can someone tell me what years of Dodge Caravan body parts are interchangeable with my 2002. Front end of vehicle in particular
Old Feb 11, 2015 | 12:03 PM
Cooreman's Avatar
Cooreman
Dug this one out of the grave.. You'd have better luck on a caravan forum.
Old Feb 11, 2015 | 01:11 PM
onemore94dak's Avatar
onemore94dak
https://dodgeforum.com/forum/dodge-caravan-23/
Old Jul 10, 2020 | 05:19 PM
Dennis Jones's Avatar
Dennis Jones
Default Interchangeable
I have a 1989 Dodge Dakota Sport and need to change out the rear end assembly. What years are interchangeable with the 1989.
Thanks
1987-1996 are all interchangeable. I myself even thou mine is 2wd I changed the hubs so they are now 5 on 4.5 instead of 6 on 4.5. 1987-1990 had the 5 lug and 1991-1996 all had 6 lug wheels.
Old Jul 10, 2020 | 09:45 PM
RalphP's Avatar
RalphP
1987-1990 bolt straight in; 1991-1996 uses six stud axles, so to keep your brakes and wheels, you'll need to swap the axle shafts.
2WD and 4WD don't directly interchange, though; and if you're 4WD, you NEED to make sure it's the same ratio as what you have now.
RwP
Old Jul 11, 2020 | 12:32 AM
Dennis Jones
Thanks for the reply. All I want to do is swap out the entire rear end from my 1989 dodge dakota to which ever rear end will interchange with, and its a 2wd auto.
Old Sep 4, 2020 | 01:09 PM
Dearolddadsgarageexperiment's Avatar
i went to pull and save and found 4 Dakotas the only one that had the trim pieces around the headlights was a 97 and they almost fit so i took them back and found an 89 but the only difference is the 89 has orange sig lights and my 90 has clear. these parts must break alot because they are very difficult to find.
Old Apr 28, 2021 | 09:20 AM
Joseph Mcgouirk Jr.'s Avatar
Joseph Mcgouirk Jr.
I have a 2000 dodge Dakota quad cab, I know that the door panels aren’t a direct fit from a 02. But what I don’t know is, could I take the doors from a 02 and put them on a 2000 without complications? Is the door latch in different locations or the door harness plugs different?
