Cylinder head bolts V6 3.9l
Hallo
I am changing the head gasked on my Dodge Dakota v6 3.9 l 1991.
I try to find the right head bolts for it, can somebody give me a hint where i can order them.
I already looked in many pages but no success, there verry rare, i need them urgent. Thanks for your help. Kall Dall
found this on the internet.
Fel-Pro Head Bolt Set Dodge Dacota Ram 1500 3.9L V6 1994-2003 ES71038
other/more info. http://dodgeram.org/tech/gas/specs/3_9v6.htm
why? Those are not torque to yield bolts, and can be reused without issue
TTY bolts are the ones that say to torque to *ft lb then torque again to ** ft lb then add 1/4 turn... the 91 and older 3.9 takes the same head bolts that small block mopar V-8 engines have, all the way back into the 1960s
the * and ** are not site edits for bad language, I just put that symbol there because the actual spec varies for different engines
