transmission temp gauge questions....
Old Feb 2, 2013 | 01:38 AM
jake122288's Avatar
jake122288
Default transmission temp gauge questions....
Hi, i ordered this the other day,
http://www.ebay.com/itm/52mm-Tinted-...item519e584e5d
and it should be arriving soon....
I was wondering if there was a test port on the transmission that i could use for my sender....
Personally want to avoid the output lines, as in a test port or the pan will give more accurate readings.
I also would like to avoid the pan if i can.
Just looking for insight.... btw its a 1991 5.2 automatic 4x4...
Old Feb 2, 2013 | 11:41 AM
keilkravec's Avatar
keilkravec
Theres a link to one in the FAQ2 section, easiest way is to just get a temp sender for an LA dakota, 91-down i think, the one that an eyelet can go over and just have a nut over it.
Old Feb 2, 2013 | 05:16 PM
volaredon's Avatar
volaredon
you want to tee it into the line feeding the cooler for best results
