OD solenoid.
Old Feb 5, 2013 | 02:36 PM
teejoker12's Avatar
teejoker12
Default OD solenoid.
hey guys,
I pulled the OD (aka tcc) solenoid from the tranny the other day. I want to replace it to try to fix my overdrive issue. when I pulled it out I noticed that the assembly has two solenoids. one on each side. when I look at advanced auto parts there is only one solenoid on the assembly. did someone install the wrong one? I'll post pics when I get home from work. thanks.
93 Dakota 194xxx miles 4x4 3.9L
Old Feb 5, 2013 | 04:34 PM
teejoker12's Avatar
teejoker12
Default Crap
Could someone help me identify what I found at the bottom of my transmission fluid pan. I know it cant bee good. thanks for any input, I might have found my OD problem....
https://mail-attachment.googleuserco...E7oFofBNY2zHbI
Old Feb 5, 2013 | 04:37 PM
teejoker12's Avatar
teejoker12
lets try this picture instead,
Old Feb 5, 2013 | 10:02 PM
Crazy4x4RT's Avatar
Crazy4x4RT
It sure looks like a piece of one of the clutch packs. Definitely needs a rebuild before it completely kills over.
Old Feb 5, 2013 | 10:58 PM
teejoker12's Avatar
teejoker12
thanks crazy. how much should that cost, roughly. I just don't want to get screwed over.
Old Feb 5, 2013 | 11:09 PM
Crazy4x4RT's Avatar
Crazy4x4RT
$2,000 if you let the shop do EVERYTHING.
$1,000 if you remove it and take it to get rebuilt.
The only bad thing about you doing the R&R your self is if there is a warranty issue where it needs some work done on it, they will require you to remove it completely and take it in.
Old Feb 9, 2013 | 12:17 AM
maxxheadroom's Avatar
maxxheadroom
There are depending on the transmission a few clutch packs in there, they will consist of a steel plate, then a plate with clutch material, then another steel, then another plate with clutch material ect ect. What you have appears to be one of the steel plates that obviously has been broken. A lot of people are intimidated by automatic transmissions but really when it comes right down to it they are just like any other machine. If it was mine I would pull it, tear it down, rebuild it and put it back in. You will be spending a fraction of the cost of having a shop do the work for you.
