ball joint replacement questions
Old Feb 8, 2013 | 01:23 AM
daksnbeers's Avatar
daksnbeers
Default ball joint replacement questions
Alright so it seems that a the seal to my upper ball joint on the passenger side has ruptured so apparently accourding to some searching on google i need to replace the whole ball joint. MY questions to this is should i replace both the upper ball joints for each side or does it not matter and will i need an alignment after i do this.
Will be my first time doing suspension work... Atleast it's not another "not starting" problem for my dakota.
All imput is appreciated.
Old Feb 10, 2013 | 10:05 PM
moe7404's Avatar
moe7404
my idea is any ball joint change needs to be aliened. did you pump to much grease in to the joint? be carefuill
Old Feb 21, 2013 | 06:41 PM
bran1har's Avatar
bran1har
If the joint isn't shot, then you can get away with just pumping a a bunch of grease in there on a VERY regular basis. Other thing is just replace me all, they are silly cheap on rockauto.com.
