Brake Line Fitting Help
Old Feb 18, 2013 | 09:26 PM
red_line's Avatar
red_line
Default Brake Line Fitting Help
Curious if anyone happens to know the size of a couple brake line fittings. I need to replace the line from the combination valve to where the line changes to rubber before the rear axle. So I need to know what fitting is at the combination valve and what fitting is at the rear hard line to rubber line transition before the rear axle. I know to use 3/16 line. Thanks for any help!!
Old Feb 18, 2013 | 09:52 PM
volaredon's Avatar
volaredon
standard fittings that come with the 3/16 line
Old Feb 19, 2013 | 07:04 AM
red_line's Avatar
red_line
I read that somwhere but couldnt verify it, thanks!
Old Feb 19, 2013 | 12:33 PM
red_line's Avatar
red_line
Anyone else with input or can verify?
Old Feb 19, 2013 | 09:33 PM
volaredon's Avatar
volaredon
I have replaced lotsa brake lines on Dakotas yes I can verify.
IF there is an issue drill the rusted chunk of tube outta the old fittings and reuse on the new line. done that more than once on various vehicles
Old Feb 20, 2013 | 10:12 AM
red_line's Avatar
red_line
Excellent. Thanks for the help!!
Old Feb 21, 2013 | 08:18 PM
Tom A's Avatar
Tom A
Section Moderator
If you know exactly what you need these guys should have it.
I bought some fittings from them when I changed my master cylinder.
