Bump shift problem
Old Feb 23, 2013 | 02:52 PM
TheGunther's Avatar
TheGunther
Default Bump shift problem
Hey,
I have an automatic 95 crew cab with the 5.2 engine, and sometime i have a problem with it shifting.
Sometimes from Reverse to Drive it will hesistate to shift for a few seconds, sometimes 'jumping' into gear.
Also sometimes happens when I come to a stop sign, ill stop, press gas a little, and the truck will 'jump' into gear, sometimes squeaking the rear tire.
I bought this truck about 8 months ago, and used it a few times a month to haul our jetski to the lake and back, some around town driving. Havnt had much worry about this issue, but I am concerned of course.
I noticed the transmission fluid looks brand new, bright pink, which i was happy to notice at first. I was just reading that the wrong transmission fluid can cause a 'bump shift' but i wasnt able to find the exact definition of this. I am thinking it is what is going on with my truck.
I dont have any shifting issues in any other gear than 1st.
Thanks and look forward to hearing input!
Old Mar 4, 2013 | 12:14 AM
Crazy4x4RT's Avatar
Crazy4x4RT
The fluid should be more red then pink. It might help to do a full fluid/filter change on the transmission, as well as adjustment of the bands. Any shop can do it for you for $100 which is reasonable.
