Frozen doors
Old Feb 25, 2013 | 12:59 PM
Hansm14's Avatar
Hansm14
Default Frozen doors
What can you do to unstuck your doors and then to prevent them from freezing up,without breaking the plastic latch? Had them froze for the first time. Any little tricks? Thanks
Old Feb 25, 2013 | 01:10 PM
cd36's Avatar
cd36
I just usually grab it by the window frame at the top, and gently pull. As far as preventing it, well if you just washed the truck, give all the gaskets and door frame a quick wipe.
Old Feb 25, 2013 | 07:53 PM
moe7404's Avatar
moe7404
i got some windshield washer fluid. i have not tried it yet. i put it in a spray bottle, spray it on the ice on the door. it might work.
Old Feb 26, 2013 | 12:27 PM
volaredon's Avatar
volaredon
spray silicone lube on the door seals
Old Feb 26, 2013 | 01:41 PM
arro222's Avatar
arro222
I've had some luck with swabbing the rubber with vegetable oil. Has to be reapplied regularly however.
Old Feb 26, 2013 | 02:03 PM
inuchan187's Avatar
inuchan187
Generally I just pull the handle a little bit and then grab the door at the top where it is pulling out a bit. Some guys I go wheeling with have a crowbar mounted on the outside of their truck to open their doors when they don't open, but that might be a bad idea unless the side of your truck just slid into a rock.
Old Mar 1, 2013 | 08:18 PM
shadowthedakota's Avatar
shadowthedakota
ive had luck with pouring hot water on the seals...till the water got on my seats once...
Old Mar 2, 2013 | 12:45 AM
Rabid21's Avatar
Rabid21
I just shoulder check my door when it freezes lol.....Works everytime
