Replaced Fuel Sending Unit
Hey guys I just thought I would share a little information about my truck. I bought my truck about a year ago and since I bought it I have had the truck cut off on me a few times while coming to a stop with the my foot off the gas pedal. I replaced a bunch of parts with performance parts and it never gave me any more trouble so never thought much more of it. I have run the truck at the strip a few times and noticed a surge right before the truck shifted into the next gear. I was never able to find the source of the problem and it only did it a handful of times. About a week ago I noticed my fuel pump was making a louder humming noise than usually. My fuel gauge has always been off a little and found that out by running out of gas once. The gauge was only off about 1/8th a tank. A couple days ago I had made a long trip and on my way back my truck started acting up while going down the interstate. The truck acted just like it did the time it ran out of gas. I was able to exit off and check the fluids, plug wires, and vacuum lines but everything looked ok. The truck started to run better so I got back on the interstate. After a few miles it started acting up again so I exited off once more. I went ahead and put $20 worth of gas in and brought it up to 3/4 of a tank. I made it the rest of the way home with no issues and the truck ran just fine. After thinking things over I decided to go ahead and buy a new fuel pump. I changed the fuel pump out today and all my problems are gone including the surge at WOT. The truck has 147,000 miles on it and I'm not sure if the fuel sending unit has been changed before but it had a round metal filter on the bottom and it is a Carter unit. The new fuel sending unit I bought from NAPA and was a Carter with a round metal filter on the bottom. I had to reuse the rollover valve and didn't want to break it so I cut the fuel sending unit housing up and used snips to cut the plastic up to the grommet on both sides and the plastic broke allowing me to just pull both pieces off the grommet and install into the new unit. I just wanted to share this information for those that may have some of the same issues going on with there truck. Hope this is helpful to someone in the future. If anyone has any questions please feel free to ask.
Glad all worked out for you. Does the sender work better now? It sounds like it was rubbing the tank wall.
I've seen several posts recently about fuel pump issues. I am not sure why people are dropping the tank rather than pulling 8 bolts, dropping the spare, 3 plug wires, 3 screws on the fill neck, and taking the bed off. It makes it 100 times easier for testing, and replacement of the pump. Plus it lets you look things over to make sure that all is well.
