dodge stock radio
Old Mar 15, 2013 | 12:45 PM
todd1976's Avatar
todd1976
Default dodge stock radio
can anyone tell me what the green and black connector is for in the back of a 1994 stock radio? i m trying to put a aftermarket one but i cant get any power. i bought the harness adapter matched color for color still no power. the radio is good just took it out of my other car.
Old Mar 15, 2013 | 12:47 PM
Crazy4x4RT's Avatar
Crazy4x4RT
I will move this to the 1st generation Dakota sub-forum. In that section you will find the FAQ. Which has wiring diagrams along with the factory service manual with the wiring diagram.
Old Mar 15, 2013 | 07:20 PM
Brian in Tucson's Avatar
Brian in Tucson
There are two power supply sources for the radio (and sorry I can't figure out the colors from the wiring diagram in the FSM.) One is always on--it maintains the radio's memory and the setting on the clock--but doesn't keep the radio or the illumination on. The other is a keyed source--only comes on when the ignition switch is in an on & running position. You can scope these out with a multimeter set to the DC 12 volt scale. If you don't have a multimeter, get one. Harbor Freight always has one on a coupon for free with a purchase. If you were local to Tucson, I'd happily loan you one of the 5 I have in my tool box--they are so inexpensive, I toss them out when the battery dies.
I would get a factory service manual as well. Haynes (I have one of those) just isn't good enough. The Factory Service Manual is the bible--everything else is inadequate.
Old Mar 27, 2013 | 12:58 PM
todd1976's Avatar
todd1976
thanks guys
Old Mar 29, 2013 | 01:41 PM
bruteforce3's Avatar
bruteforce3
Here you go:
http://www.the12volt.com/installbay/...etail/696.html
I used to be an installer and used this site from time to time. Here's another good site I used for wiring info when putting in remote starts:
http://www.bulldogsecurity.com/bdnew...gdiagrams.aspx
Hope these help.
