Auto Trans. swap
Old Mar 24, 2013 | 04:10 AM
mohook's Avatar
mohook
Default Auto Trans. swap
My 1987 4x4 Dakota's 3 speed W/OD transmision stoped working. I would like to use a newer stronger trans. when I replace the old one. What would be a good replacement?
Old Mar 25, 2013 | 11:40 PM
Crazy4x4RT's Avatar
Crazy4x4RT
You can try an auto from a Ram or Ram Van or Dakota from 92-95. The V8 version will stronger but it might suck down a little more HP. So sticking with a V6 transmission may be a good idea. You might need to swap around electronics and add in switches for OD/Over Drive and the TCC/Torque Converter Clutch lockup.
Old Mar 26, 2013 | 07:21 PM
shadowthedakota's Avatar
shadowthedakota
i found a minor difference between the 2 transmissions and that was the throttle rod didn't work for me.
