Where'd my CAD go?
Old Apr 8, 2013 | 07:58 PM
axmking's Avatar
axmking
Originally Posted by Hahns5.2
Put T-case in 4wd, jack up ONE front tire, attempt to rotate tire. If the tire doesn't rotate, everything is fine. If the tire rotates and the driveshaft doesn't, something is awry in the diff. If the driveshaft rotates, something is awry in the T-case.
Ya following that instruction, the tire does rotate while the front driveshaft does not... so looking like the diff
Old Apr 8, 2013 | 08:47 PM
axmking's Avatar
axmking
Well looks like a stripped the $&@? out pinion gear to me. Ring gear partially stripped too
Old Apr 8, 2013 | 08:49 PM
Tom A's Avatar
Tom A
Section Moderator
Wow, that's pretty ugly. I think you can safely say you found the problem.
Old Apr 8, 2013 | 09:04 PM
axmking's Avatar
axmking
Oh ya . It's one oily relief haha. Well time to pull em out and get to the junkyard this week. Thanks yall
Old Apr 9, 2013 | 09:04 PM
Tom A's Avatar
Tom A
Section Moderator
Where are you located, and will a front axle from a 97 fit? I just happen to have one sitting in my garage.
Old Apr 24, 2013 | 09:14 PM
axmking's Avatar
axmking
I believe it will. I'm in central oregon.
Old Apr 24, 2013 | 10:42 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Sorry but 1st gen and 2nd gen front axles are not interchangeable.
Old Apr 29, 2013 | 08:39 PM
axmking's Avatar
axmking
Well that sucks a fat one. So could I pull something from a Cherokee or wagoneer or get to seriously modding for a straight axle. I just need a cheap front end possibility that can be made to work. Preferably one with the same gear ratio. I'd like to keep the chopping and welding at one end of this ugly beast
Old Apr 29, 2013 | 09:02 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Just replace the ring and pinion. Under $200. http://www.ringpinion.com/b2c/PartsL...D=321&CatID=35 Try ebay too. Chrysler 7.25 (Chry 7.25 Front and rear axle parts are the same)
A SAS you will be looking at $2,000-up if you do the work your self.
Old Apr 30, 2013 | 09:15 PM
axmking's Avatar
axmking
You sure? Those prices on a set of new gears is the same as a rolled Cherokee (from a Craigslist idiot). Especially if you make your own shackle extensions and weld it yourself. But I figured I'd see what the forums got to say on the subject, I've never owned a dodge till now
