Adjusting air pump/water pump belt.
Old Apr 10, 2013 | 02:14 AM
Moffman's Avatar
Moffman
Default Adjusting air pump/water pump belt.
Reinstalling the belts on my 3.9l 87' Dakota and the p/s, and alternator belts were easy but I'm having a bit of difficulty with the air pump belt. First what was odd was the bolt and nuts appeared to be metric instead of SAE. Anyway the pivot bolt here:
Adjusting air pump/water pump belt.-qfwgv2x.jpg
It took a lot of force to break it loose and it began to make cracking noises with every turn once it finally did, like a rusty exhaust bolt but at the same time I worried it may be reverse threaded.
Adjusting air pump/water pump belt.-tbjrzgk.jpg
Adjusting air pump/water pump belt.-skrgsj5.jpg
I have the tension set and tightened the other bolt you have to loosen and really have no idea how I am supposed to tighten the pivot bolt. Are you just supposed to let the nut's "tab" bottom out against the pump while tightening it or am I missing something here?
Thanks
Old Apr 10, 2013 | 04:27 PM
MacDak's Avatar
MacDak
Hmmm, that looks different than mine. I don't know about that tab either. If my pic is not too big, here is what my '93 looks like:
Old Apr 10, 2013 | 05:37 PM
cd36's Avatar
cd36
93 will be a single serpentine belt, 87 I believe has 3 different belts.
Old Apr 11, 2013 | 02:54 AM
Moffman's Avatar
Moffman
No worries, basically it was how I thought the "nut" just bottoms out against the pump. Don't understand why there wasn't any sort of attachment for a socket or drive on the nut plus the tab though.
