95 dodge dakota v8 wont pass emission test
Old Apr 14, 2013 | 01:11 PM
roberthd69's Avatar
roberthd69
Default HELP 95 dodge dakota v8 wont pass emission test
95 dodge dakota v8 wont pass emission test. here is readout.
15mph hc max= 88 me= 186 co max=0.45 me 0.55 no(ppm) max=508 me=1371
25mph hc max=37 me=98 co max=0.54 me= 0.15 no(ppm) max=533 me=631
anybody know whats wrong????pls help
Old Apr 14, 2013 | 10:48 PM
Crazy4x4RT's Avatar
Crazy4x4RT
The typical things that would cause problems would be the EGR Oxygen sensor and the catalytic converter.
Old Apr 19, 2013 | 12:03 PM
Brian in Tucson's Avatar
Brian in Tucson
If you have an EGR, check for clogged egr ports on the valve or a leak (NOx). Make sure your ignition is completely up to snuff--good wires, plugs, cap, & rotor (HC.)
But really if you can't figure it out, the best first money you can spend is to take it in for a smog diagnosis--the guys at the smog check station may be able to suggest a shop. It will be a lot cheaper than just randomly replacing parts.
I had a Fiero with emissions problems, it was a worn out catalytic converter. Replaced the cat and it promptly passed.
