HELP 95 dodge dakota v8 wont pass emission test
Old Apr 14, 2013 | 01:40 PM
roberthd69's Avatar
roberthd69
Cool HELP 95 dodge dakota v8 wont pass emission test
95 dodge dakota v8 wont pass emission test. here is readout.
15mph hc max= 88 me= 186 co max=0.45 me 0.55 no(ppm) max=508 me=1371
25mph hc max=37 me=98 co max=0.54 me= 0.15 no(ppm) max=533 me=631
anybody know whats wrong????pls help
Old Apr 14, 2013 | 01:43 PM
moe7404's Avatar
moe7404
try a half tank of e-85. it might run bad but it might pass. just a thought.
Old Apr 14, 2013 | 02:34 PM
roberthd69's Avatar
roberthd69
thank you
Old Apr 14, 2013 | 02:37 PM
roberthd69's Avatar
roberthd69
thank you what is e-85???
Old Apr 14, 2013 | 06:40 PM
inuchan187's Avatar
inuchan187
85% ethanol 15% gas. Depending on where you are in the country, there might not be any around you. My closest station is over 100 miles away.
there are lots of reasons to fail. bad o2 sensor, bad cat, timing is off, burning oil or antifreeze. if you still have the original cat, replace it and you will probably pass. I wish they did sniffer tests where i live. I have a car with OBD2 that fails because of a check engine light for a cat even though everything has been replaced. If they had the sniffer test in PA, it would pass with flying colors. On the OBD1 cars, if you have a cat, you pass. You could have a hollowed out cat and piles of smoke coming out of the exhaust and you would still pass.
