V8 is having a real rough time starting I recently cleaned my iac I'm not sure if I may have done some thing there. It seem to be when it sits for about 5 hours or longer when I give it about half on the gas it starts quicker (less turn overs) but is still rough. Should I start with the spark plugs and work my way back?
Today when I approached the first stop sign after starting at about 3-5 km/h so just before I stopped it felt like it lost all its guts it held like that for a 1-2 seconds but when I applied the gas it chugged a bit and went like it had no problem
Update: I changed my idle rpm speed to a more comfortable idle I am replacing the spark plugs as to they are old and slightly out of gap. I personally believe it is me temperature sensors because i believe it only happens when it is cold. Has not happened for the last day or two
