tie rod ends
Old Apr 20, 2013 | 07:34 PM
dodgedartracer's Avatar
dodgedartracer
Default tie rod ends
hows any one had a problem buying the correct tie rod ends for there dakota? mine is a 92 rack and pinon manual steering fleet truck. the ones the autozone oriellys napa and carquest sell for have the right size hole(14 x 1.5) for the rod to screw on but the tapered shaft (.54 small end and .63 large end) is to small. part number es2850. the one for a power steering truck has to big of a hole(15mm) for the tie rod but the tapered shaft is the right size (small end is .63 and the big end is a .71). is my problem because its a fleet truck?
Old Apr 20, 2013 | 09:48 PM
dodgedartracer
the ones i removed was m14x1.5 tread for the tie rod and a taper of .63 small end and .71 large end. with a taper length of .63.
