Rear axle is clunking in automatic trans
Old Apr 23, 2013 | 02:20 PM
gonetothehills41's Avatar
gonetothehills41
Default Rear axle is clunking in automatic trans
I have a 94, v6, 3.9 club cab. The transmission was just replaced and now the rear axle (transfer case?) clunks when it is shifting gears. What should I do? Will (and how) just checking/filling the gear oil be sufficient?
Thanks
Old Apr 23, 2013 | 03:59 PM
BKCowGod's Avatar
BKCowGod
First thing - check to make sure it's not play in your driveshaft. At the joints, if there is too much play you will get a metal-on-metal clunk.
