94 dakota temp guage problems *****help*****
Old May 5, 2013 | 04:11 PM
b1ueange122's Avatar
b1ueange122
Default 94 dakota temp guage problems *****help*****
Ok im not sure of thos os 9n the right place or not so if it is not my apologies . Here os my problem I have a 94 dakota 3.9 motor and at forst my temp guage wasnt reading at all so i looked under the hood and say that the single wire sensor was broke so I changed the single wire sensor first and to my amazement my guage worked . But it read max hot all the time will changing my two wire sensor under I think every one is saying under the ac compressor . Will that fix my problem . O and I just bought this truck 132.000 miles and the water pump and the radiator was just changed before I bought it if that means anything please helpppppp
Old May 5, 2013 | 06:12 PM
shadowthedakota's Avatar
shadowthedakota
does it stay on hot when you turn on the truck when its cold? sounds like a short in either the new sensor or in the wiring leading from the sensor to gauge
Old May 6, 2013 | 10:40 AM
b1ueange122
It reads hot when the truck is off and when its on lol
Old May 6, 2013 | 11:31 AM
MacDak's Avatar
MacDak
If it reads hot when off, at least you know it's not really hot. Still needs fixin though.
Old May 6, 2013 | 10:19 PM
b1ueange122
Also at 60 mph what rpms should I be at
Old May 7, 2013 | 08:05 AM
DakotaRT1993's Avatar
DakotaRT1993
Should be around 1700 to 2000 RPM, but it depends on gear ratio/auto or manual trans/tire size
Old May 7, 2013 | 09:42 AM
b1ueange122
Hmm im thinking something may be wrong with my tranny im almost at three
Old May 7, 2013 | 09:43 AM
b1ueange122
Auto trans stock rims and gears
Old May 7, 2013 | 01:33 PM
shadowthedakota
sounds like overdrive isnt kicking in
