charging problems 1991 v8
Old Jun 1, 2013 | 11:17 AM
waswiftsr's Avatar
waswiftsr
Angry charging problems 1991 v8
ok, after reading a lot of threads on this site and others i have yet to get a clear picture of the charging system on my 1991 dakota w/v8 tbi.
i know the voltage regulator is in the ecu.
i understand the charging control via the field coil.
i have read many times about the battery temp sensor (the one that none of the parts stores ive contacted, not even dodge lists for this vehicle). the earliest parts list refernce to a bts is on a 96.
i cannot find a connector for one on the drivers side firewall or fender. I have seen what they look like on newer models at the wrecking yard.
i have not found a bts on any wiring diagram for this year or as an input to the ecu.
my ecu connector has a blue wire on pin 10 going to one side of the field on the alternator and a dark green going to pin 20 from the other field terminal.
this morning, for maybe 30 seconds, the input to the field was pulsing, it stopped, and did not come back even after restarting.
both the battery and alternator bench tested (off the truck) good.
before i spring for a new ecu, i want to be certain there is no bts on this model and the wiring is correct.
does anyone have wiring diagrams for the 1991 that actual show the bts and its inputs to the ecu???
i'm no stranger to mechanical or electrical trouble shooting, i do howerver like to have as much CORRECT information as i can get before changing costly parts.
can anyone provide correct diagrams or links to then?
Thanks
Art
Old Jun 2, 2013 | 11:54 AM
Crazy4x4RT's Avatar
Crazy4x4RT
I would start by checking for continuity in between the alt and pcm.
I will move this to the 1st generation Dakota sub-section.
Old Jun 3, 2013 | 10:09 AM
waswiftsr's Avatar
waswiftsr
Default charging
i have checked the wiring from the field terminals to the ecm.
dk green goes to pin 20 reads 0 ohms
blue goes to pin 9 0 ohms
fuesable link and wiring from alt to bat 0 ohms
cleaned and measured grounds, all 0 ohms
went ahead and ordered a re-man ecm, keeping fingers crossed it fixes the issue. hopefully will know by the end of the week.
ill update the result.
thanks for the responce.
Art
Old Jun 21, 2013 | 08:16 PM
waswiftsr's Avatar
waswiftsr
the good news is th replacement ecm fixed the charging problem.
the bad, it only lasted a few hrs.
I will be rechecking for either of the wires to the field coil being shorted to ground.
I will also be unwraping the wire bundle from the alternator connection block to the ecm looking for any wiring issues.
any other suggestions??
Art
