91 Dak 4x4 transmission question
Old Jun 11, 2013 | 08:14 PM
Hav0k's Avatar
Hav0k
Default 91 Dak 4x4 transmission question
I figured I'd stop in here before I start freaking out about getting a transmission rebuild, so what's up, I hope I can get some help that will save me some money.
Problem: Today i was trying to pass a vehicle on a 2 lane, and as I start to pass him I see my speedo jumping around, then when I pass him, the speedo pretty much died, and it wouldn't shift into overdrive. It happened after I got about half way around the guy.
I had 1st 2nd, 3rd was a bit sketchy, but it still works sorta, and 4th(OD) is pretty much non-existent. I think maybe a sensor went bad or something, as the transmission was running fine throughout the day. I checked the fluid, it's where it should be, and it's still pretty clean, I'm sure it could use another service though.
So is my hunch right, because I really hate to go to a transmission shop and hear them tell me I'll have to pay a ridiculous 3000$ for a rebuild.
Old Jun 11, 2013 | 11:39 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Sure sounds like the speed sensor on the transfer-case which sends speed data to the PCM, which then the PCM controls the Over-Drive (4th gear) and TCC Torque Converter Clutch lockup (which is why 3rd sucks). The speedometer cable is attached to that sensor.
Old Jun 12, 2013 | 12:11 AM
shadowthedakota's Avatar
shadowthedakota
agree...i wish this was what went wrong in my truck...
Old Jun 19, 2013 | 12:08 PM
Hav0k's Avatar
Hav0k
Thanks for the heads up, That seemed to be what the problem was. I took it to pepboys and they figured out something had disconnected, they fixed it no charge.
