what flywheel do i need ?
hi guys my 12 sec motor is finally done i got a nv3500 to put behind it but i need to know what flywheel i need the motor came out of a 2002 r/t dakota and i know there is a 130 tooth flywheel and a 143 tooth one what one do i need and what truck can i order one from this is my last thing i need to do plz help!!!!!!!!!
From what I can tell on www.rockauto.com and www.napaonline.com it depends on what clutch you get. Factory part number is 5300 6742 which can be found in the FAQ, see if you can find anything that cross-references. You posted up 3 times, I deleted 2 of them. You can always give your old post a BUMP if needed instead of starting a new one.
