Trailer Tow Packages for 91 Dakota?
Old Jun 19, 2013 | 12:12 PM
Hav0k's Avatar
Hav0k
Default Trailer Tow Packages for 91 Dakota?
I was wondering which vehicles I could look for that have the same or very similar frame mounting points for a tow package.
I'd like to snag one off craigslist or anywhere I could find it for cheap if possible, I'd just like to know what trucks I could just swap straight over from. I looked online and brand new they are around 165$, hopefully I can find somebody hard up for some cash. :P
Old Jun 19, 2013 | 07:58 PM
keilkravec's Avatar
keilkravec
junk yard. I got mine off another dakota of the same body, universal adjustable one for about $35. you'd be amazed how many people dont remove them after a wreck or when they junk it.
Old Jun 19, 2013 | 11:06 PM
BKCowGod's Avatar
BKCowGod
Looks like a Curt Class III would be $129 shipped from Amazon. Not quite $35, but no rusty bolts to fight and better than $170
Old Jun 20, 2013 | 11:04 AM
keilkravec's Avatar
keilkravec
lol suprisingly enough the one I got had no rusty bolts, just ghetto rigged with really long wheel studs O_o
Old Jun 21, 2013 | 01:06 AM
BKCowGod's Avatar
BKCowGod
nice... you lucked out. I love ghetto rigs. I once owned a car that had every single wire replaced with brown lamp cord. Best part, it was two-prong lamp cord, but the PO had only used one side and just left bare ends on the other side. Hate.
Old Jun 21, 2013 | 11:25 AM
Brian in Tucson's Avatar
Brian in Tucson
Depends on what you want to tow, doesn't it? If you're towing a little utility trailer, a motorcycle, a seadoo, or a small boat, the hitch ball hole in your rear bumper is strong enough.
If you have time to go scrounging the yards, you may find a used one--a wire brush, some black paint, and maybe some new bolts & you might get away with about $50 for the hitch. You'll need to wire up the lights--but that's not too bad a job.
If you don't have time or are flush, get the one off Ebay or Amazon. I put the Kurt (Curt?) brand on a Lumina for towing my m/c trailer. Worked just fine and was first rate.
I got lucky when I bought my Dakota--it came with the factory tow package. I moved the connectors out of the welded on box on the bottom of the hitch frame and to a new connector thru one of the license plate light up on the bumper. Out of harms way and looks factory.
One of the things I noticed towing even my small m/c trailer with the KLR on it was that the truck really, really tends to understeer so slowing down on curvy roads as necessary. (My truck is a 96 4wd, and I am a chicken!)
Brakes are just fine, and one tends to want to turn the overdrive off & gear down on the mountain grades. Btw, my truck has lots of miles, a 5.2, & the 3.55 gearset, and using the o/d on the flats, I got an honest 20 mpg on a 1500 mile (with mountains!) trip last fall.
Old Jun 21, 2013 | 04:16 PM
shadowthedakota's Avatar
shadowthedakota
i would recommend a junkyard or craigslist if you want to go on the cheap(they can pull them off for you also) like everyone else stated. i've pulled light trailers with a ball on my bumper and it was ok but i can turn the truck and trailer better with a hitch/reciever (and the tongue of the trailer doesnt sit as high.
Old Jun 21, 2013 | 04:23 PM
Hav0k's Avatar
Hav0k
Well, this dakota is pretty beast for having a v6, I run a small lawn and landscape business, and sometimes I find myself pulling pallets of sod around with a double axle trailer.. I've towed some heavy stuff with it, but my problem now is that the bumper is starting to bend, and there is a crack from the base of the ball hitch that goes directly under the bumper.
I didn't check amazon, so I'll look there.. I know the local U-Haul will install one for ~200$ plus wire up the lights. As far as going to a junk yard, that may be an issue since there aren't anymore around locally, and the ones I checked online that were a little further away didn't have anything I could use.
If I can't pull one off any other vehicle, what year dakotas would I be able to get one off of? only 1st gen?
Old Jun 21, 2013 | 09:08 PM
BKCowGod's Avatar
BKCowGod
Again according to Amazon, Reese makes the same hitch for 1989-2004 model Dakotas, with the caveat that our Daks require drilling two holes.
Amazon.com: Curt Manufacturing 13280 Class III Receiver: Automotive Amazon.com: Curt Manufacturing 13280 Class III Receiver: Automotive
Old Jun 22, 2013 | 10:19 AM
volaredon's Avatar
volaredon
got mine (Reese class III) on half price day at the pic n pull (not a misprint) I paid $12.50 because it was half price... and it was brand freakin new
it came off a 96 Dakota that just hit the yard... I also got the new 3 row copper/brass radiator from it too.... I hate aluminum/plastic ones (like stock)
IIRC they show the same hitch fitting 72-93 full size Dodge also fitting 87-96 Dakota
its not like the old days when the same hitch would fit any pickup...
from full size Jeep to international or Ford Chevy and our Dodges...
its a far cry from that now a days
