92 dakota 3.9 timing chain
I just picked up a 92 dakota 3.9 from my freind for almost nothing to use as a work truck
. But i believe the timing chain is loose and i want to change it. I know basic stuff but never tried internal stuff yet. Is it hard to replace? Also if i got the timing chain kit without the tensioner how long would it last before it stretched again?
I just know shops want any where between $500-$1200 and thats to much. So i want to try to replace it. Also what all parts would i need?
I need to do all that it has not slipped or broke. I could not just line the marks up on the old one then just install the new one? I actually don't care about all that performance stuff, it is just a old work truck.
Ok so i finially have time saturday to do my timing chain. The problem is none of my local parts stores have the tensioner, and i don't want to wait for one to be shipped. If i put just the sprockets and chain in how long would it last? Is it a good idea or should i wait for a tensioner to come in?
Ok i got a haynes repair manual and it does not give me any torque settings. Could some give me any torque settings for everything including waterpump bolts? Also if i had a factory manual would it give me the torque specs?
Trending Topics
In Haynes there are some torque specs at the beginning of the chapter on the V6 & V8 engines. Some not all.
When in doubt, use the generic torque specs they list on page 0-10, in the front of the manual. On the water pump bolts, just to be extra safe, use copper gasket goop, RTV to seal the threads when you put them in, I like to snug them down with a socket and then give them about a quarter turn more. Gentle, tho, it doesn't take gorilla strength.
