Trailmaster Kit
Old 07-12-2013, 12:11 AM
Tom A's Avatar
Tom A
Tom A is offline
Section Moderator
Dodge Forum Moderator
I guess mine's different because it's a second gen, but I had a massive crossmember I had to cut off to fit my leaf springs. I do have a steering box, but the later years have rack and pinion and it's not a big deal to add a steering box. I'm just saying, it might be some extra work, but a frame swap isn't exactly trivial, either.
Old 07-12-2013, 01:45 AM
rx7_dude2003's Avatar
rx7_dude2003
rx7_dude2003 is offline
Ok yea, there was other differences as well like trans crossmember rear leaf spring brackets n blah blah blah but I like the 4x4 frame I looked stronger than the 2wd. I also fully boxed my frame all the way to the rear for extra strength
Old 07-12-2013, 07:46 AM
Tom A's Avatar
Tom A
Tom A is offline
Section Moderator
No problem. I wasn't trying to argue with you or anything. Just trying to understand what you were talking about, since my first gen experience is extremely limited. Thanks.
Old 07-12-2013, 10:11 AM
saywhaaat's Avatar
saywhaaat
saywhaaat is offline
I understand that a 4x4 frame will be easier in the end, just depends if I can find one i decent shape, thats why I love the fram I have now, its in such good condition for its age, no rust, no wiring corrosion, nothing, minus the obvious faded paint which will get changed anyways, I am aware of the little extra work on a 4x2 compared to a 4x4........I will be doing a little off roading but mainly this truck will be used as my DD/ tow truck when I tow my drift car, and of course taking it out on the beach to camp. If I am able to find a 4x4 frame in good condition at a good price Ill probably jump on it, but I have no problem doing the little extra work, because either way its BUILT not bought haha
DOes anyone know if the 242 matches up with the NV4500?
Old 07-15-2013, 02:55 PM
rx7_dude2003
No problem here Tom (: Was just stating my opinion on what I prefer n what I did is all.. But I would find a 4x4 frame n fully box it in.. If u want pictures of my frame lmk it turned out really nice I'm very happy w how strong it is n the bed doesn't flex away from the cab like my old Dakota.. N I'm running one ton axles w 40" tires..
N for the 242 I'm not sure what is it out of n I'm assuming its electronic shift? Usually the out put shaft on the nv4500 is 29 spline... Since ur doing a cummins I'd look for a NP241ld or NP241dhd (what I have in my mud truck) they can in hd trucks n diesels cummins of course.. Worst case is u may have to swap input gears to tcase to mate to trans depending what spline out put shaft u have w ur nv4500
Old 07-15-2013, 03:53 PM
saywhaaat's Avatar
saywhaaat
I appreciate all the opinions that is why I am here Would love to see those pictures, boxing in the frame, it is def a must, i can torque my current frame just from rocking it back and forth let alone towing something haha
and the 242 is the np241 but it has 5 selections instead of 4 (Full 4x4, 4x4 hi, 4x4 low, N, and 2 hi
Old 07-18-2013, 11:04 AM
rx7_dude2003
Icic with the tcase.. If u already have it use it if not I'd honestly look for a DHD or LD cause I mean how often are you going to use the full 4x4 option?
As for the frame I got the idea from seeing my old Dakota only on 33"s flex like a bitch.. I pretty much took every nut and bolt, lines, clips n brackets off the frame down to nothing.. Here's a few pics
The start lol
Cutting everything off but engine mounts!! EVERYTHING!
Being a dork wishing the project was done already lol
Boxed in to the very last rivited in cross bar thingy
Hercalined the intire frame
If u kno these frames trucks the rear fuel tank/ bed mount bracket / crossmember was taken off for the boxing of the frame because part of that cross bar gets bolted to the inside of the frame..
This is what I did after the frame was boxed I cut that cross bar to fit in the frame again n completly welded it to the frame inside as pictured n on top with no bolts..
Finish of the bed liner
2wd v6 body n frame being stripped for body n panels
Easiest way for us... Takes about three four guys to pull n hold so it don't tip.. Pretty easy actually
Bye bye old frame 2wd v6 w blown engine
Engine trans n tcase installed
Cab installed
N I pretty much built off from there
Old 07-18-2013, 11:19 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Crazy4x4RT is offline
Nice job rx7_dude2003. Did you post up a SAS build thread yet? I would suggest doing it and add all of these pictures.
Old 07-18-2013, 11:21 AM
rx7_dude2003
Thanks. I will one of these days I kno a few of u asked for a build thead when I first came to this page haha
Old 07-19-2013, 01:54 PM
saywhaaat's Avatar
saywhaaat
Great Pictures really appreciate that....and true honestly I probably wont be using it very often
your right that does seem a lot easier to deal with a 4x4 frame, you should make a write up fer sure.
Quick Reply: Trailmaster Kit
